Anyone know the difference between CoCUT Pro X4 and Greatcut?
Discussion in 'General Software' started by Cutter-Up, Apr 15, 2010.
  1. Cutter-Up
    Cutter-Up New Member
    2
    I tried the 30 day free trial of CoCUT Pro X4. It looks the same as GCC's cutting software Greatcut. Does anyone know if there is any difference between the two? Are their just more drivers available for the Pro version?
    Thinking about buying a GCC Jaguar and curious to know what the included (Greatcut) software is.
  2. royster13
    royster13 Very Active Member
    1,817
    2
    38
    Apr 3, 2009
    Montrose BC
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,567
    423
    83
    Sep 11, 2003
    Olympia, WA
    No direct knowledge but an educated guess would be that it is probably a private label version of CoCut ... not CoCut Pro, and probably only has a limited set of drivers.
  4. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    cocut standard
    CoCut Standard - Skin
    Plot Manager
    Test Drive
    Duplicate, position, scale objects
    Cut by color
    Sophisticated segmenting of XL plots
    Cut preview on foil width
    Cut parameter selectable (material, speed, number of copies)
    Material consumption display
    Vinyl optimization
    Cocut Pro (which I use)
    Cutting Software - CoCut Professional
    Professional cut plug-in
    for Corel DRAW,
    Illustrator, Freehand, AutoCAD
    CoCut Professional - Cutting Software
    Recommended for:
    - professional signmaker
    - screen printers
    - textile signage
    - multi user solutions
    CoCut Professional - Request 30 days trial
    New in Release 4X4:
    * Autoimport plug-ins for CorelDRAW X4/X5, Illustrator CS3/CS4 and AutoCAD 2008/2009/2010
    * PDF import filter
    * Job-Info
    * 'Adjust objects' tool
    * Drivers for SummaCut-R series, Roland GX series, a. o.
    Product info
    Do you want the best sign making solution that money can buy? Look no further than CoCut Pro. It adds high-end sign making features for color printing and fully automates the print-and-cut process with advanced support for Summa's revolutionary OPOS contour cutting system and other producer's alignment systems.
    But CoCut Pro and CorelDRAW are more than just the ideal print-and-cut solution. Three different Welding options make all clipart files instantly vinyl-ready, so you'll never pay for over-priced sign making clipart. And Inline/Outline contouring creates cutting paths around vector illustrations or bitmap images with unparalleled speed and efficiency. CoCut Pro, when paired with the incredible power of CorelDRAW, easily outperforms anything else on the market - including sign making programs costing thousands more. This functionality is either given with Illustrator, Freehand and AutoCAD.
    CoCut Professional 4X4 Highlights:
    CoCut Professional - Skin
    Plot Manager
    Visual Job Manager
    Contains all functions of CoCut standard
    Move, scale, duplicate, clone objects, ...
    Converts pencil thickness into cuttable outlines automatically
    Jog marks function
    Register marks with „Print & Cut” Support
    Automatic color & screen print welding
    Drag & Drop (with CorelDRAW)
    Screen print function
    Segmentation of oversized plots
    Cut preview
    Displays material consumption
    Foil optimization
    POWERweedTM
    FOTOcutTM
    Great Cut
    # GreatCut Highlights:
    # MultiSkin
    # Plot Manager
    # Visual Job Manager
    # Move, scale, duplicate, clone objects, ...
    # Converts pencil thickness into cuttable outlines automatically
    # Automatic color & screen print welding
    # Screen print function
    # Cut parameter selectable (material, speed, number of copies)
    # Jog marks function
    # Register marks with „Print & Cut” Support
    # Drag & Drop (with CorelDRAW)
    # Segmentation of oversized plots
    # Cut preview
    # Displays material consumption
    # Foil optimization
    # POWERweedTM
    # FOTOcutTM
    IT almost says the same thing about each other..
    So it looks like Graet cut is a rebranded version of Cocut Pro.. If it is you will love it to no end..
  5. Cutter-Up
    2
    Wow, that's a lot of great info Techman,
    Thanks to all for your reply's.
    That really helps me make my decision. I press transfer film on t-shirts and bought all the right equipment, but skimped on one thing, the cutter. Last year I bought a USCutter Laserpoint 24. It's ok for small jobs, but is far from a professional cutter. I use Illustrator with Signcut Pro on a usb connection, and it has intermittent communication issues. Hoping the Jaguar and Greatcut will solve it.
    Great forum, thanks again. :thankyou:
