Jeff jones
Looking to buy an applicator table choice between rolls roller or cwt about the same price an spec which is best?
I bought http://www.bubblefree.hu/en/applicut/about-the-machine very good no problems it came with a 5 year warranty (UK) 6m long machine
What is the difference between the Roll-X and a regular RollsRoller?We went with a Roll-X for our new office. I don't have overhead door access and so we needed a model that bolted together. We are very pleased with it.
From My understanding the RollsRoller has a fully welded stand and base with one solid sheet of glass.What is the difference between the Roll-X and a regular RollsRoller?
We recently bought a Kala Applikator... its ok, the Chinese machine we bought 3 years ago gets used more. There are some major design flaws in the Applikator product.I would go with the CWT just because there is no bridge over the roller. But if you can, look at the Kala applikator. I love this one because you can add more tables in the future.
Have you managed to fix your issues with the KakaThe biggest things that we run in to on the Kala is:
The cutting surface moves around and makes waves when using the roller, this causes issues when using high-pressure mode and trying to laminate/mask thin materials.
There is no manual or fine pressure adjustment, you get 1 2 3 and everything has to fit in that box.
You can only mask or laminate in 1 direction (if you want to use tension on the core).
The Gantry is super wobbly and can lead to angled application if not careful.
Sorry...Kala!Have you managed to fix your issues with the Kaka
Yes, we replaced the cut surface with a better one.Sorry...Kala!
