Can someone please suggest their methods here. I'm looking to see what other experienced pros are doing. I've tried to follow 3M's recommendations, and I've not been too thrilled. I've had a few times where I've done this type of sign, but mostly it's been digitally printed panels which I apply with soapy water and a silkscreen squeegie. So refresh my memory of how it's done when the graphics are individually cut with transfer tape applied.
Here's how I've done it: I clean the surfaces including the back of the liner of the graphic, tape it into position, pull back the liner and spray Rapid Tac onto the decal and the acrylic. Then I lay it down and start squeegeeing from the tape hinge, center up, then center down overlaying them halfway and work across the graphic. Then I'd pull the transfer tape off and respray to work out any fluid still retained. Here's where I usually have problems and and can't get everything down perfect and I'm fighting it trying to get it smooth, poking holes to release the fluid. Any suggestions?
