Applying Vinyl Over Holes in Truck
Betty
I have a truck that has some small 1/4" holes (an emblem was attached there) that I will be applying vinyl over. What is the best way to deal with the holes? The signage will be 1 color.
Betty
Craig Sjoquist
Fill if ya can bondo then sand smooth
It will shrink if a hole is there then show up later, you can try 2 layers one for the hole then other as ya cover normal
But longer the time more it will show ..fill is best
You can try bondo, but our experience has been.... most fillers will eventually fail and fall out anyway. If you're not a body shop or have access to one and the customer isn't willing to pay for it.... just put the vinyl over the hole and let it be. You're a sign shop, not a body shop.
BadAss
Use a piece of Mylar film (chrome or whatever) and then cover with vinyl. It strenghtens the holes.
Billct2
If the graphic will cover the hole, we put a vinyl dot over the hole (and on the back if accessible), then apply the lettering
