Auto serialize
Discussion in 'Flexi' started by John L, Nov 19, 2009.
  1. John L
    John L Very Active Member
    1,468
    Apr 28, 2007
    In Flex8.. how do you seperate elements after you have done an autoserialize. I have a bunch of boxes with consecutive numbers in them. Can't rt click to "ungroup" and didn't see a "seperate serialization" choice. I need to center all the numbers inside the boxes.
  2. BobbyFosson
    BobbyFosson Member
    401
    Did you try centering the object before running the serialization?
  3. Pat Whatley
    Pat Whatley Major Contributor
    8,592
    86
    48
    Sep 29, 2003
    Wetumpka, AL
    Select them, hit "CTRL+U" works for me.
  4. John L
    1,468
    Apr 28, 2007
    Centering prior works fine for 1 through 9. After it gets to double digits it jumps over off center.
    Cntrl U doesn't do it on mine... Flex8Pro
    It's OK. I just did it all manually. Thanks.
