Banner Pricing
IKD
I was curious as to what everybody charges for finished banners with lettering applied per square foot. I'm just starting out so kinda having trouble figuring how much everything is worth. How much does everyone mark up their supplies from cost. Thanks
Ryan
ChiknNutz
Mine vary PSF. I use sort of a tiered pricing structure, meaning that small things are more expensive PSF and it gets cheaper (up to a point) the larger it is. Example: 1-color 2x4 banner is $63 ($7.88 PSF) and a 1-color 4x10 is $251 ($6.28 PSF). Each add'l color is about 25% more. This is for cut vinyl stuff, I print most of my banners anymore, but the philosophy is the same. I mark up my mat'ls a true markup of 40% (which is 1.67X cost, or cost/0.6). Some things I double (true markup of 50%).
oc63rag
Check for local market prices also. Don't assume the street price is $X per sq. ft. without verifying. This way you'll be competitive without leaving money on the table. Your customers, hopefully, will tell you whether your prices are out of line or not.
bob
I use the following algorithm that calculates a price such that the large the work, the less per sq.ft. I use a variation on this algorithm for most all my prices. The variables are...
Max is the maximum per square foot price. This is what I'd get for a 1 sq. ft. banner.
Min is the minimum per square foot price. This is the absolute minimum for which I'll work.
Area is the unhemmed length*width.
Matl is the cost of material unrolled for this project.
Min*Area+Max-Min+2*Matl
This yields a pleasant curve that starts at Max per sq.ft. and becomes asymptotic about Min per sq.ft.
I use a Max of $24 and a Min of $6.
IKD
Ok called up one of the larger sign companys in town and usually thought to be most expensive and they said 8-10 bucks a sq/ft. Prob call up a few more to see what the average is. Thanks guys
