use water + a few drops of dawn detergent next time
and dont install perf wet
Thanks. I had to peel it to dry the water this morning. I definitely will get a helper to install it dry next time.
Any thoughts on the font for "2016"? I don't think it's Jubilat.
It's actually "FreightSans", as mentioned above. Thanks!
No. It's perforated film, that's why there seems to be bubbles. I ran out of application fluid, so I sprayed water instead. The edges were still wet.
You did a wet application of laminated perf?
That's almost as wrong as supporting Bernie Sanders.
the OP was asking about fonts and application, not looking for political opinions.
Au contraire, the OP was most certainly delivering a political statement, as deranged as it is, under the guise of a rather lame request for information. If it were apolitical, it certainly could and most likely would have been done a bit differently.
follow up post showing the end result not withstanding, the thread is a request for a font ID and nothing more
Twaddle. The rear window image and triumphant accompanying text are hardly what one might expect from a simple request for a typeface identification. While the question of what typeface to use may have scampered across what passes for the OP's mind, the dubious political statement is, or at least should be, blatant even to the most casual observer.
by 'triumphant text' do you mean 'what do you think?'?
I don't find that to be quite up to par with my definition of triumphant...
edit: AND, is the political statement 'dubious' merely because of the content, or would any rear window decal referring to political pundits be 'dubious' in your eyes?
So... This "(please look him up if you are not familiar. He's an awesome guy.)" wasn't in the original post?
OP did not just ask for a font, he also plugged said candidate and encouraged everyone to check out how awesome said candidate is. That opens it up for comments.
It's the bang after the title on that particular post that put it over.
Perhaps a bit of each but the preponderance of dubiousness is a full rear window devoted to silly political purpose. Or do you, or anyone else, think that such a ghastly display is going to sway sufficient of the electorate as to put, at best, a fourth tier comic relief candidate in office?
actually it doesn't as the OP may have brought a political topic to a site that forbids it doesn't mean the rest of us get to comment. just ignore and stick to the topic which was "what font is this". it keeps things on topic and doesn't get clouded with personal opinions.
