Best print setting for JV3 printer
Awards+
We have a JV3-160 and was just wondering what the most used / recommended print setting would be. How many passes and overprint?
SightLine
Cannot remember offhand what we ran for fast low end use banners etc but for most vehicle wraps and things to be seen up close pretty much always ran 720x720 8 pass.
SARTampaBay
720x720 8 pass bi (uni if small text is involved), 360/540 for banners usually at 3 pass if we can keep the media comp dialed in.
artbot
in rasterlink pro II it also has an option called "fast print" it is available or goes gray depending on how many passes are chosen. if you give it more than the minimum, and choose "fast print" the head carriage goes into full speed.
