If the Rivets come off I like to remove them for doing cut vinyl but this isn't always an option. I have used the rolle pro on cut vinyl around rivets and it does the same trick as it does when using sheets of vinyl. I think it is the best tool for rivets on any application type.
The Torpedo Tool is a completely useless item. I have one, have used it and it is/was a waste of time and money. Thankfully it wasn't that expensive so it wasn't a large waste. Last but not least a good technique using the old faithful rivet brush will work as well.
Basically you want to use what you're comfortable with and what you think gives the best result. Persoanlly I like the Rolle Pro cause it's quick and very hard to screw up.
Must say that rolle pro is the best. At first I couldn't get the vinyl over the rivet completely flush, but after figuring the amount of heat to use....BAM!!!! There it was, nice clean rivet.
Love the rolle pro + torch or heat gun.
jc
i heard the "ideal" temp to heat up is approx 180-200c is that about right?
- The temp will drop the minute you pull the heat off so the time it takes to set down one of the tools to pick up your rivet tool the vinyl will have cooled already. My advice is to take a scrap piece of material or cut vinyl and practice using it on a line of rivets. Get used to the amount of heat you want to put on it and just practice. You'll figure it out real quick how long of a flame burst you will need to heat it properly. You'll notice how the vinyl looks when its at a correct range of temp. And soon enough you'll be ready to blow through a 60' Semi with a line of rivets every 20"!hahaha, I wish I knew that secret.Yes - however you can't have a torch or heat gun in one hand, a IR Temp. gun in the other and in the third hand your rivet tool - unless you have some sort of secret that no one knows about- The temp will drop the minute you pull the heat off so the time it takes to set down one of the tools to pick up your rivet tool the vinyl will have cooled already. My advice is to take a scrap piece of material or cut vinyl and practice using it on a line of rivets. Get used to the amount of heat you want to put on it and just practice. You'll figure it out real quick how long of a flame burst you will need to heat it properly. You'll notice how the vinyl looks when its at a correct range of temp. And soon enough you'll be ready to blow through a 60' Semi with a line of rivets every 20"!
