Signature Sign Guys
Hey I am wondering what the best uv lam and vinyl is for a window graphic that is in direct sunlight for most of the day? what do people suggest using? 3M - IJ ?
Arlon 3420 would last a good 4-5 years in those conditions. We have a large sign that faces south in Denver so it gets blasted with sunlight pretty much all day. It started cracking and discoloring at about the 4.5 year mark. The 3220 would resist cracking more and may have a longer UV protection value but I'm not sure.
No to hijack the thread, but I take it you're a fan of Arlon? What print material from them would you use? We've got a supplier trying to push some of their products. Specifically the 4600lx to replace 3M 40c. I use their cast cut vinyls, but not their print.
I have used the arlon 3420 before but it hasn't been outside for to long to know the full results but if you say its worth it I will take your word for it. Our supplier also suggested briteline laminate which we have been using. Any thoughts on that material?
Not a fan of the Briteline laminate. It seems to shrink up fairly quickly.
I've not used that.. it's been a few years since I've used Briteline so hopefully the cast formulation is a lot better. I'm not even sure they offered a cast when we were using it.Specifically the UV Lam? They have also come out with a cast UV Lam. Wonder how it's going to do.
