Big Circle...
How common are CNCs that can cut a 94" circle? Everyone I know who has a CNC is 4'x8'.
No, I don't think it's common at all, either. Not sure why you are asking, but I'll try to clarify for you. When I first suggested using poly, it would've needed to be hand cut, in most cases. Not a problem, as anyone can hand cut a perfect circle and maybe hafta sand to get some of the little yuxes out of it. However, when everyone was suggesting using two sheets, it's quite hard to finish off four separate corners of the curve and keep them all perfect. A CNC could keep them all..... absolutely perfect. It would then, butt up swimmingly.
shoresigns
You suggested a CNC in a follow up post after the one I quoted, so I thought you were suggesting using poly to do the circle in a single piece, with a CNC.
