Bloching??
82R909
Not sure if its a term or not but in my solids like the Blacks, magentas, reds... its not solid anymore ive done serval cleanings and still continue with this problem any ideas? and its on a vp-540 thanks
joeshaul
Could be a variety of things, first thing that springs to my mind would be the heater's off and the material is cold, this can cause the ink to kind of pool on some materials. A picture would help us determine more though :)
Are you using OEM and using the correct profiles for the media you're running through ??
82R909
Pic coming in like few and yes jillbeans i meant blotching it was very late and fustrated. I am using oem ink and i did 8 of the exact same 4ft sticker before this happened on the 8th one...
82R909
82R909
sorry bad quality but im working on tryin to get my digital camera over here from a jobsite thx for the help
Looks like some form of contamination..... and to that color only. However, are you using CMYK for black or straight Black only. Possibly something has gotten into your line and when large amount of K are being used it forms a type of fisheye and puddles up or circles around an oil spill within your lines or cartridge.
82R909
that sounds complicated and yes im using 100%k .. so pretty much i need to call a tech out to my place?
It was just a suggestion. Don't fret until some more knowledgeable people answer you.
mgliss
Was there a possibility of overspray from any chemicals on the material? Sometimes during a cleaning I have unknowingly gotten flush on the vinyl and had the same type of problem. My second guess is that something is wrong with your heater or its not turned on.
mgliss
Mike Paul
Super Active Member
Probably contaminated material.
What are you printing on? Have you tried a different roll?
Try raising the heat.
What's the makeup of your black?
Bly
Is bloching anything like felching? :help
Either too much ink for the media or contamination.
Was this occurring before on this vinyl?
82R909
im using 0 0 0 100 i had already printed 8 of the 4ft stickers already and the 9th one came out looking like that ... i tried to re print... 40c on print 45c on dryer same result ... I havent tried a different material because its my last roll of the RA. I will try on a different oracal and see the result ..... Where can teh contamination come from?... I appreciate all the help
jasonx
100k black in your artwork doesn't mean 100k black is being printed.
If you want that setup a special colour in versaworks so when ever it sees 100k black it will print 100k black regardless of the profile.
Also Under the Printer menu in Versaworks theres a Test Print.
Print that one and show us a pic of it.
