Bluetooth - anybody doing it ?
Discussion in 'Miscellaneous Hardware' started by Buddy, Jul 7, 2007.
  1. Buddy
    Buddy Member
    492
    Is anyone using bluetooth connections between their computer design station and equipment such as plotters and printers ?
    BUDDY
  2. mbarden
    mbarden Active Member
    596
    2
    18
    Oct 1, 2006
    Iowa
    Not really worth the trouble. Short distance and not very fast. Might as welluse something like Linksys wireless adapter.
    Mike B
    Big River Sign Co.
  3. andy
    andy Active Member
    848
    1
    Dlink wireless network gear works very well for me- fast, secure and simple to set up.
  4. Buddy
    Buddy Member
    492
    My plotter has parallel & serial (RS232C) ports only. No USB. Is there a wireless defice that will create a connection directly between my laptop and the plotter ? I don't think so.
  5. Air Art Girl
    Air Art Girl Very Active Member
    1,907
    4
    get serial-2-usb adaptor
  6. mbarden
    596
    2
    18
    Oct 1, 2006
    Iowa
  7. Buddy
    Buddy Member
    492
    Thanks Mike....you hit the nail on the head.
  8. jiarby
    jiarby Major Contributor
    4,513
    Run a wire if you can... faster & more reliable. Those wireless & USB external print servers continually lose connections. You can get an old HP Jet Direct ethernet print server for about $25 anywhere with up to three parallel ports on it. Then, if you HAD TO, you could attach a 802.11 Wireless Bridge to it, but I'd run a cable.
  9. Buddy
    Buddy Member
    492
    http://www.iogear.com/main.php?loc=product&Item=GBP302KIT
    I wonder how something like this would work ?
    Regarding dropping the signal....it seems like once the file has been transferred to the plotter memory then it's a done deal and the plotter is cutting out of it's own RAM or ROM.
  10. John Butto
    John Butto Very Active Member
    2,310
    3
    38
    Jan 9, 2007
    bluetooth
    I use a Palm TX with bluetooth and a GPS buetooth device, good up to 10' away, but to run a device such as a plotter or large inkjet you do not transfer information as you say in a large amount quickly such as a cable does and then let the plotter take over. Bluetooth is design for streaming information at contuinous time on small devices such as phones, PDA's, keyboards, mice etc. They do make bluetooth USB port plugins and I wish you luck in trying to get a plotter to run efficiently. If you want to go wireless look into WIFI by plugging your plotter or printer into a wireless router and your WIFI computer which is fairly simple.
  11. Buddy
    Buddy Member
    492
    thanks guys.....I think I got the picture.
    Basically........it won't work like I was thinking anyway. Especially since bluetooth is more for streaming data vs. off loading bulk data.
    I think I'll drop that idea.
