Braille directly on door
Discussion in 'General Signmaking Topics' started by De.signs Nanaimo, Jun 25, 2012.
  1. De.signs Nanaimo
    De.signs Nanaimo Member
    67
    15
    8
    Nov 25, 2010
    Nanaimo
    Hi all,
    I have a designer who has Braille wash room signs directly on the door surface, just the raised dots, and the wood background. I am looking into using doming resin to make my own on dots of vinyl, but am stumped on any other options. Anyone done something like this before? Andy
  2. J Hill Designs
    J Hill Designs Major Contributor
    15,549
    16
    maybe applique brailledots from scott signs?
  3. CES020
    CES020 Very Active Member
    2,875
    4
    38
    Oct 16, 2008
    VA
    Why did they put a braille sign on a door? If you open the door, the sign essentially goes away for the blind person that would need it.
    You are not supposed to put ADA signs on doors unless you have zero other place to put it. If there's room to the right or left, the code, as I read it, says it HAS to be on the wall when available.
  4. visual800
    visual800 Very Active Member
    3,849
    244
    63
    Aug 4, 2010
    montgomery, alabama
    esspecially when most plaques are in a spot where the blind thing they should be this would just jack them up!
  5. J Hill Designs
    15,549
    16
    yup ADA signs need to be on the wall, handle side of door, 60" up to center
  6. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    hhhmmm?!?! Maybe it's different in CANADA?
  7. J Hill Designs
    15,549
    16
    oh ya, eh?
  8. De.signs Nanaimo
    67
    15
    8
    Nov 25, 2010
    Nanaimo
    Yea thanks guys, I may have to recommend they go with a full sign or something! Still waiting to hear from the doming resin people, and I put an enquiry into Scott Signs!
  9. MikePro
    MikePro Major Contributor
    4,827
    201
    63
    Feb 3, 2010
    Racine, WI
    pfft. doming resin? just make a template, drill a tiny hole, and place a glass bead in it.
    just don't tell the raster-braille people that I just released the secret of their patent.
  10. petepaz
    petepaz Major Contributor
    4,315
    77
    48
    Feb 14, 2007
    NJ/NY/PA
    i think doming on vinyl would be a bad move. high risk that the dots could fall off. not enough adhesive surface to grip and if dots start falling off the braille may go from saying men's room to pee here(that could be a problem)
  11. CanuckSigns
    CanuckSigns Very Active Member
    3,221
    326
    83
    Nov 11, 2008
    Ontario
    we do quite a few braille and tactile signs in Canada, I have never heard of putting the braille right on the door, as others have said, when the door is open the sign dissapears, and if a blind person is reading it and someone opens the door into their face, it could be pretty bad.
    A person who is blind relies on things like the ADA specs to make their life easier, some architects we have run across don't like signs and view them as a necessary evil, as a result, they try to do things like hide them on the door etc. which doesn't work.
    One architect we did work for told us that this new wing in the hospital wouldn't need any signs because the design is so intuitive that everyone will know exactly where to go, needless to say, we had to go back and add a bunch of directional signs because everyone kept getting lost.
    On a side note, the domed vinyl dots won't work, braille dots must be 1/16" in diameter in order to be read, vinyl dots that small won't stay put, especially after a few people run their fingers over it.
  12. amw
    amw Member
    If you drill the right size hole you should be able to put a raster braill bead in the hole. You would just need to make a template of the hole locations. But as others have said, the sign shouldnt go on the door unless you have no other place to put it.
    Marsha
  13. CanuckSigns
    3,221
    326
    83
    Nov 11, 2008
    Ontario
    We have the raster braille kit, I've seen quite a bit of hate towards the system by sign shops online and i've never understood why. the kit and licence is not expensive to buy, I think it's around $2000. we paid for the kit about 3 times on the first job we used it on.
    My understanding is that the "braille insertion pen" is that actual part that is patented, not the process of putting a bead in a hole, you are free to drill a hole and put a bead in it however you choose to, but the pen makes the task must quicker and repeatable.
    Like I said, i'm not sure why there is so much hate regarding the raster method, it's just another tool in your arsenal.
  14. amw
    amw Member
    We have it also, and agree with you!
    Marsha
  15. TwoNine
    TwoNine Active Member
    537
    2
    Photopolymer...
    EDIT: Or like everyone else has said - Beads.
  16. MikePro
    4,827
    201
    63
    Feb 3, 2010
    Racine, WI
    <3 photopolymer
    agreed, however, that raster is yet another weapon in your arsenal. i'll continue to sub it out for now.
    I still think its a great idea to raster the door, if that is your only option.
    label on the door is better than no label at all, BUT label NEXT to the door (latch-side, particularly) is better than the former.
