This is from their Product tech bulletin when using 3M solvent based inks.
It might not apply to 3rd party or
eco solvent inks:
About Solvent Ink Printing
Effect on
Printed Images
Normally, very small amounts of retained solvent will not affect the finished graphic
characteristics or application performance. Excessive solvent must be removed through
proper drying prior to applying graphic protection (overlaminate or clear). If it is not, the
graphic protection will trap excessive retained solvents. This softens the film and allows the
solvent to migrate into the adhesive. Softened film is more likely to stretch, curl, bubble, lift off the liner, pucker, or shrink when handling and during graphic application. In addition, the solvent in the adhesive will contribute to more aggressive adhesion. The result is poor application characteristics. Also see About Drying Printed Film on page 7.
Completely and Properly
Dry Printed Film
Be sure you have read the section, About Solvent Ink Printing, page 4.
• Use the highest printer dryer setting that does not distort or damage the film.
• Slower printing speed allows the film to be in the dryer longer for more effective drying.
• Additional drying options
- An auxiliary dryer may be used to complete the drying.
- You can air dry on racks, although it is less effective than oven drying. Typical air
drying at 270% total ink coverage is 12 hours; higher total ink coverage may need
up to 24 hours.
- Reducing total ink coverage reduces retained solvents and reduces drying time.
• Troubleshooting
- Change the temperature or drying times only only if you observe problems.
- Too much heat in the drying process may result in any of the following. Reduce the
heat to correct the problem.
• Film problems, including liner blisters and film shrinkage.
• Transport problems in the printer.
• Wrinkling when the printed film is overlaminated or premasked.
- The drying time varies for each film and the total ink coverage of its image.
• To check dryness, use the Dryness Test, below.
wayne k
guam usa
