I subscribe. You guys cut about a billion stickers on a bunch of $10,000 Graphtecs. Perhaps I should take that as a hint.
And since I have you here: In one (or more) of your videos you had said you had dedicated kiss cut and perf cut Graphtecs. Which brings me to wonder:
1. Does the workflow go smoothly moving it between cutters with the bar codes?
2. I assume you do it this way because of the blade position. I know it's possible to do both kinds of cut over the channel. Is this a bad idea?
3. Why not get into flatbeds with your volume? I know you have at least one Zund but I assume for boards. Not worth the money for stickers?
4. If you're sticking with roll cutters why not Summa that can do perf and contour all in one job?
Ok, I'm done for now. Probably not.
Id like to openly assist on some of these questions from our POV.
1. You can connect many FC9000s to a single job folder. barcode server will work flawlessly over them all. We use the same concept with our summas.
3. Its cheaper to run a $10,000 vinyl cutter to thrucut small stickers vs a zund or a summa F series. There would be efficiently to gain using a flatbed cutter, but also space will be an issue. If we ramped up our die cutting products, we would go straight to a summa F series flatbed or a Zund S series.
4. We only run Summa vinyl cutters. We sold our Graphtec after buying multiple Summas. The Graphtec have a cutting channel and is far easier to thrucut stickers. With the Summa, you need to thrucut on the cutting strip which means replacing the $50 strip ever so often. You also wouldn't thrucut and kisscut on the same pass. you'd do kiss 1st, then the other.
You can also do this on the FC9000. if you leave the blade in the cutting channel, you can get it to thrucut and kiss cut without removing the vinyl.
Summas i think are a better machine, Only if you're kiss cutting.
