LightHouse
I use a graphtec FC7000-75 30" cutter and it can't pull a full log of vinyl without getting an error and if you are cutting something longer than a couple feet it will go off track. Its a nightmare...
i owudlnt be quick to put something down, ovbiously your techniques are of. i can cut 30 feet without going off track with the exact same plotter. you might want to try the pre feed option or manually rolling out the vinyl you will use for a job and let it drape over the rollers. if you need mroe help with some tips PM me.
