can´t run summa d60 with latest winplot
1234
hi,
i use summa d60 without usb, so it runs with
summad60 (parallel plug) -------------------> pc (serial plug), or
summad60 (parallel plug) --------------------> pc (usb plug)
for some reasons i´ve to reinstall windows xp, and now i´ve problem to
run my plotter propperly.
i know there is no special driver for it. usually, first you install winplot, than
choose connection, parallel or usb, and finally choose LTP ,or other ports.
if i choose the blue , and like to cut via plug-in of corel x3, it says :
"fail to get extents from cutter CUTCMD_FAILNODEVICE".
if i continue clicking ok, then it finaly works.
on the other hand, when i connect the red, pc finds immediately the cable.
it recognizes it as "IEEE 1394 Bus host controllers", but doesn´t work, neither from com1/usb nor ltp port.
i´m totally lost. any idea please??
thanks alot
george
1234
thanks for advice.
i´m just curious, why it worked before without any problem??
i may forgot something unimportant, and now i pay the price :)
by the way, the main problem is, that i´ve to install plotter like
a new printer, and it can´t find it anywhere.
best wishes
GTArt
hi,
thanks alot
george
Hi I'm having the same issue on a Summa D750 and I'm just inches away of selling it and buying something
more easy to setup.... :(
Did you manage to make it work and how?
Many thanks
Asuma01
This post is almost 10 years old. You are better off just writing up a new post. Since it seems like you are having problems I reccomend contacting summa support. Its what I did when I first set up my summa plotter and they helped me get it going.
GTArt
GTArt
Hi,
I know it's a bit old but like you've seen it the person I was asking might see it too and I'm trying to ask anyone has experienced similar issues as I have contacted Summa Support and they're quite slow to respond at the moment..
