Can NOT import eps to flexi sign pro
Discussion in 'Flexi' started by nickmacri, Jan 20, 2008.
  1. nickmacri
    nickmacri New Member
    2
    hi if anyone out there could help me i would really appreciate it!
    for some reason my flexi sign pro has decided to stop importing eps and .ai files, before i could just drag and drop into the main square, or import any eps, ai files, but now when i try it nothing happens... no error sign, nothing! i can import jpg and giff files but no eps.
    it still opens my previously made files saved in .fs from eps files aswell
    if anyone can help me PLEEEEEEEEEEEASE
    THANKS
  2. zmatalucci
    zmatalucci Very Active Member
    try setting your prferences back to default. Just make sure that you are aware of all your connections (tcp/ip etc.)
  3. high impact
    high impact Very Active Member
    Flexi won't open an ai or eps file if it is too new of a format. I don't remember which version I couldn't open a few months ago...needed the provider to save in an older version and the file opened right up.
  4. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    If there is something truley wrong with the program, then I would think that doing a "Clear Preferences" cures a lot of issues. You can find it on the start menu within the Flexi group.
    If you are using the drag & drop method, then it only works if you have a file open. You then need to minimize the file to the task bar. Then drag & hover the .eps file to the minimized file on the taskbar, wait for the document to open and then drop the file in the document.
    One point of warning here when using this method with images such as .jpg's. In past versions of flexi, I found files were lost even after saving the file.
    For instance... a picture from the camera is on the desktop, drag and drop the image to the flexi file and save it. Now the image is deleted from the desktop because it's not needed. Next time the file is opened, the image is gone. You can see it in the preview window, but when the document is opened, there's a blank gray box where the image should be.
    Since we upgraded to 7.5, I've been told that it dos'nt happen anymore, but I have not had an opportunity to fully test it.
    The way we bring in files now is by using the import function from the "FILE>IMPORT" menu. You do need to tell it what type you are opening in order for it to work.
    JT
  5. Samm
    Samm Very Active Member
    1,173
    Import them?
    Been on Flexi for a buttload of years here and never come across one I couldn't just open!
    BTW - Welcome!
  6. Boomer
    Boomer Member
    198
    Jul 20, 2007
    Delaware
    Did you try "right click" on file then "open with" then "design software".This has worked for us before.
  7. Replicator
    Replicator Major Contributor
    10,230
    9
    38
    Nov 19, 2006
    Sun City, AZ
    Welcome . . . If you have Adobe Acrobat Writer you can convert EPS and AI files to PDF and then Import PDF . . . !
  8. nickmacri
    2
    thanks zmattalucci, you were right. it's all good now!! thanks again
