Cannot import .ai file
Discussion in 'Flexi' started by ytry, Aug 29, 2013.
  1. ytry
    ytry New Member
    14
    Mar 24, 2010
    Shady Spring, WV
    Flexi is not letting me import an AI vector. I am using an older Flexi 6.5. Any suggestions. Thaqnks, Curt
  2. rjssigns
    rjssigns Major Contributor
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    Convert to .eps and Flexi will take it.
  3. The Vector Doctor
    The Vector Doctor Very Active Member
    3,498
    144
    63
    Aug 15, 2005
    Ohio
    Either the file is corrupt or maybe it was saved to a new version. When i send ai files to customers i usually save down to version 8 or version 3
  4. jfiscus
    jfiscus Map Wraster
    3,201
    239
    63
    Apr 2, 2009
    Cincinnati, OH
    had this happen recently, I needed to install some updates... and then it happened again, just had to reboot and the problem went away. Saving it as an EPS always seems to work better though, as .ai file susually only import what is on the artboard versus everything on the"whole page".
  5. P Wagner
    P Wagner Very Active Member
    1,923
    83
    48
    Aug 16, 2006
    San Diego
    If you have Illustrator, it should be a slam dunk to open the AI there, and re-save as an EPS to get it over to FlexiSIGN. If you do not have Illustrator, or CorelDraw or similar, your copy of Flexi (6.5) is roughly 11 years out of date, and will not be able to open any of the newer versions of EPS, PDF, AI, or a host of other file types that have been created in the past decade or so. In that case, you might want to upgrade your software to a more current version.
  6. truckgraphics
    truckgraphics Member
    62
    Feb 16, 2012
    Maryland
    New Trick
    You might try sending the file to another location on your computer, then try opening it. No idea why it works, but it has worked more than once with our Flexi 8.x.
  7. ddarlak
    ddarlak Trump Hater
    9 out of 10 times when i can't get an illy file to open in flexi, I shut flexi down and start it again and the file imports fine.
