CARRIAGES DISCONNECTED ... CARRIAGES DISCONNECTED Can't Stand It
Discussion in 'Roland' started by CENTERVILLE SIGNS, Dec 27, 2013.
  1. CENTERVILLE SIGNS
    CENTERVILLE SIGNS Member
    187
    2
    18
    Dec 19, 2011
    Nutley, NJ
  2. iladi
    iladi Member
    121
    Apr 23, 2007
    Romania
    Clean or flip or replace the encoder strip.
  3. Vinylman
    Vinylman Very Active Member
    1,057
    6
    38
    Aug 15, 2005
    Berlin Center, Ohio
    Stupid is as stupid does!!!!
    ?:iamwithstupid
  4. 31legen
    31legen Member
    225
    3
    18
    Nov 28, 2013
    virginia
    Carriage disconnect
    What machine do you have. I had a similar issue and had to do a simple carriage alignment procedure. I have the instructions at my office.
  5. Drip Dry
    Drip Dry Very Active Member
    1,122
    1
    38
    Aug 11, 2004
    Long island NY
    I assume this is a Roland ?
    A few years ago, I had the same problem. The tech gave me the procedure to set the carriage back in place, but warned that it may be caused by the "cut carriage cable" That's what it turned out to be.
    Do you have other error messages such as "pinch roller error"
    If so, consider the cable
  6. lodcomm
    lodcomm Member
    174
    3
    18
    Oct 30, 2013
    Ledyard, CT
    I had that problem on my CJ-500 after messing with the carriage board.. I thought I had caused a major issue when working on it, however all that needed to be done was Limit Initialization and all was well:
    follow the procedures outlined in:
    http://support.rolanddga.com/docs/D...and Guides/Service_Doc_LimitPosVPRS_Rev_1.pdf
    That doc is for VP & RS Machines, but the exact same procedure (including the <^> Key combo) was what I used on my CJ500
    -t
