I can't stand Casmate, there's too many glitches.
I can't stand the quick keys. (If you want to call them that) You have to click on too many things, and spend too much time to accomplish one simple task (Like zooming) that would take me seconds in Flexi.
How come when I type a single line of text, then If I want to change the text to be on two lines, I pretty much have to delete the whole thing and type it again? eg: If I type "Chuck's Car Wash" on one line, then decide, I want to put it on two lines. When I put the courser between "Chuck's" and "Car" and press enter. The courser goes to the next line and the text stays exactly the same way, on one line.
Also I can't stand to draw in Casmate (It just doesn't have the right work flow.) So I created a logo in flexi on another
computer and imported it into Casmate, the lines were all flip flopped, sort of like the compound in Flexi being all messed up. (If you know Casmate, I'm talking about the red and blue lines) There all messed up and fixing them takes more hassle then it's worth.
I like the color setup, how it has all the vinyl and pantone colors but applying them to the objects, just takes too much work compared to flexi's older and newer versions.
I can only get fonts to install through the installer that comes with Casmate and only the fonts that come with Casmate will install. Adding effects has too much work involved. Not to mention there's always some kind of an illegal function to shut down the program, and you can't just start it back up because Casmate never really shuts down, it's still running somewhere, where I have no idea. (It's not in the task manager.) So you have to shut down the
computer completely.
Like I said, "Too many PROBLEMS."
My buck fifty.........................Chuck
PS: As Dustin mentioned, you should check out Inspire XP's demo. I like the way it works.
