Cast vs. Calendared Vinyl
Discussion in 'Newbie Forum' started by WestbankKurt, Jun 26, 2012.
  1. WestbankKurt
    WestbankKurt Member
    96
    Jul 1, 2009
    New Orleans, Louisiana
    Vinyl on cars
    Thank for the quick response. Why is cast the better vinyl then calendered?
  2. CS-SignSupply-TT
    CS-SignSupply-TT Very Active Member
    1,541
    1
    CAST or CALENDARED
    I got this one, y'all. Even though I do not speak CAJUN, I think Kurt will understand. CAST is manufactured by pouring the liquid vinyl to its finished size and allowing it to cure accordingly. CALENDARED is manufactured by pouring the liquid to a specific size, curing, and then "stretching" the product to its finished size. The stretching gives the vinyl a memory; therefore, over time, the applied vinyl will "shrink" back to its pre-stretched size.
  3. wildside
    wildside Very Active Member
    1,469
    20
    38
    Aug 28, 2005
    Kansas
    similar, but what i always understood, and told by a gregory rep probably 15 years ago, that cast starts as a liquid and is poured onto massive sheets and baked to cure, while calendared starts as almost like a "playdough" or putty and rolled through different pinch rollers to squeeze it down to the thin shape
    cast is stretchy and does not have a memory because it started as a liquid and has no reference point while calendared will always try to ball back up to its original "playdough" state, causing the curling and the shrinking.....
    • Agree Agree x 2
    • Like Like x 1
  4. Fred Weiss
    Fred Weiss Merchant Member
    20,926
    550
    113
    Sep 11, 2003
    Olympia, WA
    It was explained to me by a VP at the old Fasson (now Avery) ...
    Calendared vinyl starts out as a dough and is either extruded through a thin slot with pressure or rolled into a sheet using steel rollers. Either way the molecular memory of the film is that of a lump and it will want to shrink back into a lump when exposed to heat or as it ages. All that stops it from doing so is the adhesive.
    Cast vinyl is liquified and then sprayed like paint against a "casting sheet" where it dries or cures and is left with the molecular memory of the sheet it dried as. Therefore, it has no tendency to shrink as it ages.
    Cast vinyl is inherently more expensive to produce but it is also inherently superior for long term outdoor vinyl lettering and graphics.
    • Like Like x 1
  5. _Neil
    _Neil Member
    34
    Jun 24, 2015
    USA
    Other than the manufacturing process, I've been told (by a vinyl supplier) that cast will have a more matte finish, and calendared will be more glossy.
    • OMG / Wow! OMG / Wow! x 1
  6. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,752
    772
    113
    Jun 15, 2009
    Mesa, Arizona
    That's a big negative! Both are available in many finishes including matte or gloss. The cast and calendared difference is all in the manufacturing process as explained by others above. Finishes, Base Color, etc is all shared by both types of vinyl.
    • Like Like x 2
  7. Fred Weiss
    20,926
    550
    113
    Sep 11, 2003
    Olympia, WA
    :bookworm
    Absolutely not so. A good rule of thumb and a best practices rule is to always consider anything said by a supplier sales rep as untrue and made up until proven otherwise.
    :dog42
    • Like Like x 1
    • Hilarious! Hilarious! x 1
  8. Behrmon
    Behrmon Pr. Bear-Mon
    409
    58
    28
    Apr 9, 2015
    RI
    It's easier to spell.
    • Hilarious! Hilarious! x 2
    • Like Like x 1
  9. ams
    ams Very Active Member
    2,227
    301
    83
    Oct 28, 2010
    Virginia
    Because it conforms better and holds up longer, also better quality. Why go into technical details?
    • Like Like x 1
  10. player
    player Major Contributor
    4,916
    190
    63
    Apr 24, 2006
    Toronto
    For the reasons already discussed, calendared shrinks. When it shrinks (and it can shrink substantially) the adhesive either gives up, or holds and causes cracking and then peeling. Although there are some better quality calendared vinyls, most are made with cheaper materials which further degrades their quality.
    • Like Like x 1
  11. mfatty500
    mfatty500 Active Member
    824
    94
    28
    May 10, 2010
    Sugar Grove, Ill
    When they say stretched, by how much do they mean?
  12. decalman
    decalman Active Member
    804
    67
    28
    Sep 2, 2012
    phoenix
    While calendered does play second fiddle to cast, fret not, there are some excellent calendered films, on the market nowadays.
    I've seen large graphics --calendered- that I've made, 4 years later, looking very good. Note-- in the hot desert sun. 114 degree heat
  13. Jillbeans
    Jillbeans Major Contributor
    14,457
    20
    38
    Dec 24, 2003
    Butler, PA
    I was always taught that cast is a more premium product and should be used on long-term jobs and vehicles.
    Calendered can discolor and shrink, and is for cheaper jobs like corosigns.
    Love....Jill
  14. Pixels Are Bad Mmmkay?
    Pixels Are Bad Mmmkay? Very Active Member
    I think a very important point that has yet to be mentioned is that cast is also available in a much broader selection of colors and textures than calendered.
  15. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    brand also matters. some cast premium by some companies is garbage. cheap brands put out cheap cast so use a good brand if you want it to last
  16. Jeremiah
    Jeremiah Member
    351
    63
    28
    May 7, 2019
    Wisconsin
    So if that is the case. We should not use callandered vinyl outside in the sun, if you do. Do you tell the customer it won't last? Or is this thought taking it too far ? Just use it ?
  17. Gino
    Gino Premium Subscriber
    34,436
    2,626
    113
    Jun 7, 2006
    PA
    Where did you read, that ??
  18. Jeremiah
    Jeremiah Member
    351
    63
    28
    May 7, 2019
    Wisconsin
    I read it in Every post before mine, IF I consider quality is supposed to last for the customer. It was really a question on how people feel about curled up vinyl signs. Just asking for opinions.
  19. signman315
    signman315 Signmaker
    337
    102
    43
    Oct 5, 2015
    Leonardsville, NY
    Every scenario is different and judged on a case by case basis. If it’s out for a weekend then calendared is fine, if it’s out for 7 years then cast, if it’s out for 20 years then ditch vinyl and carve it. But also there’s other factors to consider...does the vinyl need to conform over curves/rivets, will it be exposed to fuel/solvents, will it be underwater, will it be applied to latex paint, does it ever need to be removed, does it apply to low energy plastic like an ATV, and on and on it goes. Lucky for us a vinyl has been developed for every scenario, it’s the printer/sign maker’s duty to test and know the specific purpose of any given vinyl type/brand and use them accordingly for the purpose they were designed. Otherwise you’re doing your customers, our industry, and your business a great disservice. Many vendors will send you free samples of various vinyls/products. Take the time to test different types of vinyl, apply them to different substrates, pull them up, wrinkle and unwrinkle them, hit em with the torch, give your hands time to familiarize with each material. Then when it comes time to choose the right vinyl for the job it will be a natural and easy choice. Well worth the time, and will stay with you for your whole career!
    • Like Like x 3
  20. litewave
    litewave Member
    40
    5
    8
    Jan 21, 2021
    Europe
    What I understand after talking to various manufacturers and wholesalers is...
    The gap between cast and good quality polymeric vinyls has been closed quite significantly by improvements over recent years. For example; one of Avery or Mactacs Polymeric products have shrinkage rates equal or almost same to premium casts and some are better than a mid range cast vinyls....
    From my discussions with a manufacturer last year for a long term outdoor application I concluded there was little to choose from in most cases. Casts are usually better suited to curved substrates (cast vinyl has less 'memory') and also can be produced by some in relatively low volumes; good for custom/specific colours. Asides that it might be the 80:20 rule, where top quality polymeric vinyls are 80% good for most applications.
