CG 160FX detecting marks erratic
jbrownb6345
Running Fine Cut software (on two different PC's). Have been using this software for over 10 years. Set up work for some decals, 10 across on maybe 50 rows. It will start off, detects marks, go to 2nd row, detects OK, cuts this row and goes to net row. I might do this OK for 10 rows, all of a sudden it starts not detecting marks as it changes row, so it skips rows. Stop reset, and I will only cut one row and very next row it wont detect. It might do this several times, then starts working OK, for about xx rows then off it goes. Sometimes when it finishes a row it will start running back to very beginning of job... Does this from both PC's. Wondering if there is some kind of "firmware update" it is missing and needs? any suggestions?
It could be that the sensor is failing. They tend to fail sporadically rather than failing out right. Is there a reason you are using crop marks on each row? Why not bundle a bunch together in one set of crop marks?
GaSouthpaw
My first guess would be the prints are skewed ever so slightly. I know all three of the Mimaki cutter's I've used have been touchy about that, at times.
If you're 100% certain the marks aren't skewed, then my next guess would be the sensor.
