LUV DEM TIGERS
Is there a way to change the default contour color? I have almost 100 numbers I have to do. They are two colors I create the numbers using a truetype font, change them to the color I want, I add a 2 color contour (of course the first color is what I want but the second color is just assigned), I break all the contours individually, I outline them with my "contour cut", and then I add a contour so I will have bleed. The issue that I have is that the default is 50% of the contour color. Is there any way to change the default to be 100% of my color. I have to go into each one and move the slider bar over to 100%. When you have almost 100 numbers it takes a lot of time.
Also if anyone knows of other steps I can change to reduce what I already do I would like to know them also. Breaking 100 contour groups and changing the outside color 100 times takes a lot of time.
