rdelight
Vehicle Wraps
Hi there,
There are multiple threads about laminators, but they're all dated.
I'm trying to pick a good reliable laminator, as I'm currently experiencing huge issues with my Master Laminator Us Tech Vt8700. It's creating wrinkles, it doesn't keep straight, it doesn't hold even pressure on both ends even with multiple adjustments and the support is literally none.
So far I found that Seal is the number one laminator in the US, but it's quite pricy which pays overtime.
What are your thoughts about GFP and Royal Sovereign?
Should I go with a pneumatic or manual crank laminator? Does the pneumatic loose air and causing issues? Does the crank press equally on both sides?
We mostly do vehicle wraps and for that, we only use cold lamination, but we also do some signs and cold laminating leaves some silvering, is this something that I should be worried and be a reason to get heat assisted one?
Royal Sovereign RSC-6500H Laminator - $12 000 Heat assisted
Seal 62 Base Laminator -$12 000 Heat Assisted
Seal 65EL Laminator - $8 600 - Cold laminator only
Gfp 363TH Laminator - $6 300 - Heat Assited
There aren't any expos coming soon where I ca go ahead and test any of those. Hopefully, you guys have more experience.
