Need Help CJV30-60 nozzle test blank
justroll
Hi
I just purchased a second hand CJV30-60, nozzle test is totally blank, no errors, cutting seems to work fine.
Head looks clean (no scratches on the head), any things that i can do before swapping out the head ?
Print Master 03
If no any error this mean that head work. If you see print head test before buying I mean hean cant dead. Check clean system of printer maybe print hard cant correct clean, and try manual push solvent to heat and check solvent easy going from head or have resistance if have resistance nedd clean head special liquid. Good luck!
Run a cleaning cycle and see if any ink moves into the waste tank. If it does and you still don't get any nozzles in the nozzle check, you probably have electrical issues. If no ink moves at all, you are probably just clogged up. I usually flush the pump out with cleaning solution to make sure it's not clogged and then change the cap top as well to make sure that's not the issue. If you have a clean pump and new capping station, you should at least be cable to get some nozzles firing.
justroll
thing is, i removed the cover from the head, and started a cleaning cycle , all the kinds the machine got , should i see this fluid moving to the dampers ? since the inkt in the dampers don't seem to move during this process at all...
since you are mentioning pump could be clogged this could be this issue then ? i hear the pump pumping .. i'll remove the right cover to so if i see something in the tubes ..
btw .. when i do pump tube wash and pump fluid into the cap (function key) it gets pumped away .. so i assume the pump is ok ?
When running a cleaning cycle you should see the dampers crush and a lot of the time you can actually hear it if it's quite in the room. Also, the pump can still make noise and be bad. The fact that solution flowed through it is a good sign that it's working. I would probably change the cap top next and see if that gets the ink flowing during cleaning cycles.
justroll
Thanks, i'll replace the capping station (i got a spare here) , also got new dampers just in case ...I was wondering if it's okay to flush the head with cleaing solution with minimal pressure ?
I see that for installing a new head mimaki advises to use a toolkit that as "S damper Assy", can't find the damper itself, is this required ? (i assume this is to avoid overpresurizing the input gates)
Yeah the official way is through the damper but honestly I always just hook the syringe directly up to the manifold. Push lightly until you see the solution bubbling out and then push a little harder and you should see solution spray out of each nozzle clearly. Just know that there is always a possibility that you damage the head doing this. I usually leave it as a last resort.
justroll
many thanks for the fast replies ! If i can do something for you in return let me know, i'm pretty good in ICT
the procedure is the same for a NEW HEAD and for unclogging a head, since the manual mentions this, btw .. what kind of tube do you use ? i got a 2mm but that seems a pretty tight fit :)
I use a soft tube that is used in the pumps. Mostly you just want it to clean if you aren't using the damper. Also be careful when pushing the solution through. The tube can pop off and it tends to go straight into your eye! I learned the hard way.
justroll
It looks like the damper they are using is a damper that is used in the JV5's (and rolands) with dx5 head, i'll just take on of them and secure it and keep presure on it, the detaching probably occurs when pressure can't get away in the head at the first moment, point of the weakest resistance and bob's your uncle...
justroll
ok .. i got the unit finally in my workshop, problem is did a full purge, now the units ask me to configure the inkts ;. SS21 is chosen, the last slot (black) is having issues; it says the cartridge is empty, or expired, or a mix, when i put the same cartridge in slot 7 it detects automatically.
i assume it is a fault in reading the chip? but the chip reads fine in slots 7, slot 8 detection goes haywire, any idea how to solve this one ?
the pump also seems to be leaking, gonna try to flush or replace the tubes, or order a new one
justroll
i skipped this procedure using 119/121 in running parameters
i opened the cartidge house for inspecting slot 8, i notice dthat the tube just falls out of the screw and that it is covered with inkt...
