Thanks, i'll replace the capping station (i got a spare here) , also got new dampers just in case ...I was wondering if it's okay to flush the head with cleaing solution with minimal pressure ?
I see that for installing a new head mimaki advises to use a toolkit that as "S damper Assy", can't find the damper itself, is this required ? (i assume this is to avoid overpresurizing the input gates)
many thanks for the fast replies ! If i can do something for you in return let me know, i'm pretty good in ICT
the procedure is the same for a NEW HEAD and for unclogging a head, since the manual mentions this, btw .. what kind of tube do you use ? i got a 2mm but that seems a pretty tight fit
ok .. i got the unit finally in my workshop, problem is did a full purge, now the units ask me to configure the inkts ;. SS21 is chosen, the last slot (black) is having issues; it says the cartridge is empty, or expired, or a mix, when i put the same cartridge in slot 7 it detects automatically.
i assume it is a fault in reading the chip? but the chip reads fine in slots 7, slot 8 detection goes haywire, any idea how to solve this one ?
the pump also seems to be leaking, gonna try to flush or replace the tubes, or order a new one
