CL catridges how do they actually work
Hulleman
Hi,
Another newbie question:
So on my SP-540 and on my XR-640 there is one slot for the CL cartridge. How does that actually work? Does the cleaning fluid run thru all the channels in the heads or where does it actually clean?
Can someone explain how the CL cartridge works? Read about the headwash requiring 8 cartridges on the xr-640, that makes sense. But what does that 1 slot CL cartridge clean?
/Julian
cornholio
SP-540 has only 4 ink slots, because it has only 4 ink channels. So no CL cartridge during normal operation.
XR has 8 channels. Depending on the ink configuration, only 7 are used by colored ink. Only then is the 8th slot is occupied by a CL2 cartridge. This is only done because otherwise it would suck air through this channel during sucking operations (cleanings) at the captop.
For headwash operation, all channels are flushed with cleaning liquid.
Hulleman
Thank you!
Graphic Extremes
Knows To Little
On the Roland xr-640 if the machine is set for white or metallic ink, you can place a cleaning cartridge in that slot so you don't waste the ink. Then when you want to print with the white or metallic ink you change the cartridge and do a couple of medium cleanings and you are ready to print with the ink. When done with the ink again swap a cleaning cartridge back in.. I did this for years,
