Hey guys...reaching out on this one since the local shop is closed this weekend. Hoping some of you actually check this on the weekends ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I took the encoder strip reading sensor off the print head carriage using a long screw driver from the top. Pulled the eye to the side (while it remained plugged in) and folded a paper towel dipped in rubbing alcohol and ran it through the gap to try and clean any residue off. Then ran the paper towel through dry to make sure it was clean.
When placing the top screw back in, I noticed the screw hole is slotted, so I was a bit unsure on where the eye should be positioned. I assumed the encoder strip should float (centered) between the gap of the sensor and the little red light. Is this correct? Does it matter? Should it touch the side that has the red light or otherwise? Please advise!
Matt
Matt
