clear vinyl and overlam
Discussion in 'General Chit-Chat' started by NGS, Dec 13, 2018.
  1. NGS
    NGS New Member
    1
    Nov 8, 2018
    Cape Town
    Hi
    Very new here and new the printing game.
    Can someone tell me all the differences between clear vinyl and over laminate and if either can replace the other at times?
    Thank you
  2. Sindex Printing
    Sindex Printing Member
    157
    39
    28
    Nov 17, 2018
    Sparks
    I have printed on both for me the ink stuck better the the clear vinyl. I honestly could have spent more time building a correct profile for the laminate. I have used laminate and it worked just fine
  3. ikarasu
    ikarasu Very Active Member
    1,939
    613
    113
    Jun 10, 2016
    Port Coquitlam, bc
    A good laminate has uv protection to protect your printed graphics. A clear vinyl won't have that.
    You can print on a laminate... We've done it lots. Is there a difference? Well... Some clear vinyl has special adhesive like control tac that allows you to reposition the vinyl. Laminate is always an aggressive glue.
    You can interchange... But it's got its downfalls. In a pinch it works though.
    • Agree Agree x 1
  4. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,295
    808
    113
    Aug 2, 2011
    Denver, CO
    Simply put, you can print on lam but you wouldn't want to use the vinyl as a lam.
    • Agree Agree x 3
    • Like Like x 1
  5. gabagoo
    gabagoo Major Contributor
    5,749
    110
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have on occasions printed on lam. The backing paper is much thinner than most vinyls adding heat will cause buckling or even tunneling, depending on the brand. 2ml lam is great to print on I must admit.
  6. petepaz
    petepaz Major Contributor
    4,347
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    printing on lam is ok they are both vinyl so will accept the same inks. the real difference is going to be in the adhesive. lam i believe has more of an optically clear adhesive that regular clear vinyl. as already stated "Simply put, you can print on lam but you wouldn't want to use the vinyl as a lam."
  7. A good laminate has uv protection to protect your printed graphics.
