Clogged Vacuum Fan
InkjetAuction
Customer calls reporting that the vacuum (SP-300V) doesn't seem to work as well as it used to. Let's just say that all of that paper dust really adds up...
~E
James Burke
Wow, that sucks...or perhaps it doesn't. But thanks to you, now it does...good job!
JB
InkjetAuction
It sucks
The service notes are silent on the service life or service interval. I supposr I would take a look at inside every couple of years--or when the suction loss becomes a problem.
I didn't take a photo of it, but the small space inside the printer where the fan blows out was also covered with a substantial amount of paper dust. This is where all of the heater junction boards live.
Anyway, it's easy to get access to the fan (just remove the rear cover) and pull it out (held in with two 3mm allen head screws). However, it's a total pain in the ass to put it back in. You have to line up the fan, a foam gasket and a couple of spacers... but the space is only a couple of inches in height. Not an easy chore of you have a large hand or arm.
It's not a super technical repair, but it's not a quick and easy fix either. Takes a good 30-40 minutes.
~E
pineguy
Had a very similiar issue...
Thank you for this post, we had a similar issue. Somehow a piece of paper made it in the fan making it extremely noisy and causing vibration. This article is the only thing I found on the web or service manual relating to the vacuum fans. Saved us a tech visit and got us back up and running!
SignEx
Thanks for post, I had always wondered if mine was working as it should, took it apart and it was full of lint/fuzz,
I could barely feel the exhaust before , After the fact I can feel it a good 4 ft away, as you said about about a 30 min job,
thanks mark
