cnc vs anything else
Drip Dry
Not saying that I can afford one, but a salesman came in selling a cnc router.
It got me to thinking... is a CNC any different than a router that carves signs for the sign industry. i thought CNC was for making metal gears and such.
Would a CNC be a practical choice to use for carving ?
briankb
When was the last time you went to a sign show?
If you are serious about getting a CNC machine wait for a major sign show and go see the different options. If it's just carving then maybe find a contractor or cabinet making show/expo.
signage
CNC = Computer Numerical Control
So a router used in the sign industry is a CNC router, a cutter is a CNC plotter etcetera.
anotherdog
Unless you are prepared for a steep learning curve and many months of learning, or to hire someone with the knowledge, you should do more research.
It would be like buying a new solvent printer with no idea how to run one or where to sell the product.
rjssigns
CNC machines come in various styles with varying capabilities. I am looking at getting a small CNC for the shop. It would be a gantry style. Only suitable for soft materials and things like DiBond.
The other end of the spectrum are the VMC's or vertical machining centers that make parts out of aluminum, steel, etc... They are built from huge castings to maintain the necessary rigidity to machine metals accurately and efficiently.
Both require you to at least know AutoCad or Solidworks or similar programs. Then be able to do the necessary toolpathing. Setting toolpaths is critical to getting the surface finish and high production rates you want without breaking cutting tools or ruining parts.
Drip Dry
Just asking the question, is there a difference. As I said in my post.. can't afford one anyway... just curious, that's all
NOPE... too old and tired to learn something new. I had trouble learning how to tie my new sneakers this morning
artbot
i've posted this type of comment before. you can make money for sign making with the worst imaginable cnc. there really isn't a "tolerance" issue with cutting out a giant letter "W". i have an ancient (25 year old) wooden frame shopbot that refuses to die. and until it does die, i can't rationalize getting something else other than i'd like to have a prettier version of the same. if you want to get into cnc, go onto http://www.talkshopbot.com/forum/ and look for one of these old kits. i bought mine for $4k 16 years ago, it sits outside in the rain on some days (accidentally). it's probably worth $1000. these are very simple machines. unless you want to engrave lightly into aluminum or do some very touchy stuff, don't bother. getting a router bit to cut a path is simple and should be extremely cheap.
this isn't my cnc but it's basically the same (mine has dual z's)
http://www.cnczone.com/forums/commercial_cnc_wood_routers/90606-should_i_buy_old_shopbot.html
