Click to Support Signs101 ...
I tried raterizing the logo and I thought it worked until I compared it with the first one...
Seems like all the background is darkened instead of having a sky blue it's more of a pale cyan
What I did was open it in Acrobat pro and flattened it under advanced print production options. Normally I flatten in Illy, but the file size grew too large to send it back to you. If you use Illy you can direct select the problem object and under "Object" select "Flatten Transparency". Be sure "Preserve Alpha Transparency" is checked and the Rastor/Vector balance is 100.
