complex file...not sure I should even attempt it
Discussion in 'Gerber Omega, Graphix Advantage & MacImprint' started by gabagoo, Oct 23, 2012.
  1. gabagoo
    gabagoo Major Contributor
    5,737
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    I have this prototype label I have to make for a client. The label is printed on clear and then put on a clear or frosted look plastic shampoo tube.
    These are great jobs for the Mimaki with no real changes having to be made to the file. This one needs to be made on the Edge because it has white in it. The label is about 4 x 6 inches and has a ton of info on it. layering galore and a small bitmap embedded.
    I know that I may have to run the job many times before I get all the layering correct and wonder from you experienced edge users if I should even bother.
    This is also one of those files whereby the designer has used masking to hide areas, and I know what that means for the Edge...trouble!!!
    How would you go about dealing with files like this?
    I was thinking of printing everything but the white parts on the mimaki and then doing all the white parts on the Edge and they can assemble it on the bottle.....you think that is unprofessional?
  2. visual800
    visual800 Very Active Member
    3,928
    267
    83
    Aug 4, 2010
    montgomery, alabama
    Isnt the shampoo bottle white? Wouldnt that make up for the while image? One thing that pi$$es me off is getting designs froma designing with all the clipping masks and what not. would it be too much to take image and crop to size and use a jpeg if your printing on edge?
  3. Matt-Tastic
    Matt-Tastic Member
    297
    1
    can you just import it as a raster, then add the white as a vector?
  4. gabagoo
    5,737
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    if that were the case I would just print on the Mimaki. The bottle is clear or a frosted look and I need to print white in some areas. A big pain for sure.
    If the graphic were larger i would make everything except the white a bitmap and then put the vectored white on top in the areas needed. But a 4 col bitmap that small on an Edge LE would result in what I think would be hideous.
  5. Matt-Tastic
    Matt-Tastic Member
    297
    1
    then do the import in parts:
    bring in vector text
    rasterize background parts (or fix them in AI and import nice ones)
    add the white spots
  6. SignosaurusRex
    SignosaurusRex Major Contributor
    8,572
    491
    83
    Mar 7, 2007
    Washington State
    ....Kind of like taking your car in to be painted and they hand you a can of paint and a spray gun.
  7. OldPaint
    OldPaint Major Contributor
    sometimes letting the right people do the job..........is the best way to go.
    how many of these you plan on printing? and i gather they need cut to size.
    there are place on the internet that do large quantity 250-500....minimum, of lables and is probably less expensive then you can do them for. this one is local to me.
    http://www.thelabelco.com/
  8. royster13
    royster13 Very Active Member
    1,817
    2
    38
    Apr 3, 2009
    Montrose BC
    For all the effort you are putting in to this, you might as well send it to Lancer Label or Stickerman.....Both do a great job of printing full colour (with white if required) on clear material.....
  9. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I have to agree with those who suggested subbing it out. I've got an Edge, but use Gill Studios for long runs as it comes in cheaper. how many are you making? if it is a really small run, get the parts of the layout as separate files and merge them yourself or re-do the whole thing.
  10. GB2
    GB2 Very Active Member
    1,928
    88
    48
    Nov 15, 2005
    Connecticut, USA
    If I understand you correctly, this is a single label prototype and therefore not something that you would sub out. There are too many factors involved to be able to tell you what to do without more detail or seeing/having the artwork, but there certainly are many ways you can accomplish this with an Edge or digital printer. This is the nature of prototype work.
  11. Marlene
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I missed that this is a prototype. charge them to reset for printing the sample and go for it. without seeing what you are dealing with, you can try taking off all the cut lines in the file, setting it on the shape that will be the decal and in plot, click on backing/finish down on the bottom of the print options page and then set it to print white behind the shapes options.
  12. gabagoo
    5,737
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    OK here is what I am doing..... I discussed it with the client who is a graphic artist anyhow. I explained to him that I might spend half a day playing around with this and the end result could cost far more than they have budgeted.
    I am going to print everything except the white on the Mimaki and then do the white with the black overlays on the edge. I will die cut the pieces and he doesn't mind assembling it on the samples.
    case solved......
  13. royster13
    1,817
    2
    38
    Apr 3, 2009
    Montrose BC
    If you want the prototype to be representative of the final product, it should be produced the same as the final product.....Last time I did a prototype like this, it cost me less than 75.00 from the label company......So even though it is a prototype, IMO is not worth messing around with in house.....
  14. mopar691
    mopar691 Member
    390
    Sep 15, 2010
    We would run it in house the the closest representation of the finished product we could. I have done hundreds if not thousands of packaging mock ups from bottles to boxes, inserts and shipping materials for the cosmetics industry.
    To outsource for a prototype to get the exact process done as the final product should not be done till the very last stage directly prior to production in my opinion. Unless you have a unlimited budget and no time frame to work with.
    To many things will change and the time line is mostly not within the customer call out.
  15. gabagoo
    5,737
    108
    63
    Oct 10, 2006
    Vaughan, Ontario
    I agree and it is not me who would outsource it anyhow...the company making the product will be doing that. The mock up is for a sales pitch to a large pharmacy chain. I am only doing what my client needs to get through the foot in the door meetings. May I add that this type of labeling is printed directly onto the bottles in the final run and not a stick on label.
  16. Browner
    Browner Member
    389
    5
    18
    Jun 28, 2005
    Winnipeg
    I used to burn through a lot of materials (and time) too, when trying to figure out complicated jobs, and then one day stumbled upon "GSP Spool File Viewer". I find it particularly helpful to confirm that overprints have been applied properly in OMEGA, and that I've checked off the correct boxes in GSPPlot for backing white foils, etc.
  17. signage
    signage Major Contributor
    9,541
    80
    48
    Oct 5, 2005
    Penn
    +1:thumb:
  18. mopar691
    mopar691 Member
    390
    Sep 15, 2010
    Same here, most bottle and jars would be hot stamped in my case. And yes many of these were done for specific retailers for the first few sales pitch meetings.
