gabagoo
I have this prototype label I have to make for a client. The label is printed on clear and then put on a clear or frosted look plastic shampoo tube.
These are great jobs for the Mimaki with no real changes having to be made to the file. This one needs to be made on the Edge because it has white in it. The label is about 4 x 6 inches and has a ton of info on it. layering galore and a small bitmap embedded.
I know that I may have to run the job many times before I get all the layering correct and wonder from you experienced edge users if I should even bother.
This is also one of those files whereby the designer has used masking to hide areas, and I know what that means for the Edge...trouble!!!
How would you go about dealing with files like this?
I was thinking of printing everything but the white parts on the mimaki and then doing all the white parts on the Edge and they can assemble it on the bottle.....you think that is unprofessional?
