Computer Wattage............
Discussion in 'Computer Hardware' started by Shovelhead, Jan 27, 2006.
  1. Shovelhead
    Shovelhead Major Contributor
    10,882
    15
    is there way to find out the wattage that your devices are putting out....
    kinda like belarc.com????
    Grazie
  2. Techman
    Techman Major Contributor
    8,520
    8
    38
    Jun 24, 2003
    michigan
    yes.. look ate wattage on the back of the components. You will be surprised..
    A 400 watt power supply in the CPU and a 130 watt monitor plus the laser printer that uses about 200 in idle.. Or, if you have a Phaser color printer that sits there using around 330 watts in idle. Add in the power used by your power conditioner/backup. It don't take long to use up $30 bux a month in power..
  3. Shovelhead
    10,882
    15
    I have a 500w supply......
    I was concerned with wattage compatibility for additional hardware....
    like if I wanted to add an external hard-drive or a super graphics card.
  4. signage
    signage Major Contributor
    9,315
    41
    48
    Oct 5, 2005
    Penn
    The wattage requirements for the hardware you have installed should be added up and that would let you know how much of the 500watts you are currently using. Hope this helps
  5. njsigns
    njsigns Very Active Member
    1,364
    2
    I have run many more things on a significantly smaller power supply. I would say that most external hard drives have their own power supply built in. I personally build my own external drives by getting the largest drive off Tigerdirect.com that I can afford (usually with a rebate too) and I buy external drive cases off of eBay. Put it together myself, and save about 100-150 bucks. It's really quite easy, I also get USB and Firewire options on the external for a fraction of the cost. Hope this helps...
    Gene
  6. Cadmn
    Cadmn Very Active Member
    2,859
    shovel you can look all the wattages up on each component & it will suprise you but 500 is usually well within normal units range now if you run 5 extra Hds& 4 extra dvds then start figuring but 5 will cover a lot of stuff.
