Are you using a crossover cable?
http://support.rolanddga.com/docs/d...ervices/manuals and guides/proii_ethernet.pdf
Am using Versa worksWhat rip software are you using? Our set up is thru Flexi production manager, add setup, then it goes step by step.
Thanks, got it sorted! Contacted local technician, going into network adapters, and changing IP4 numbers to match printer.Modern Ethernet switches and ports do not need a cross-over cable. If you are dealing with an older switch (or Ethernet port), that may be necessary.
