TheBarricade
When using "Contour Cut" with the contour option, is there any way to make the lines a bit smoother for die cutting? I understand it's following the contour of the letters, but that makes for a bit more jagged edged look. The only option I can see is to make the spread larger, but even with it at 1", it's still wiggly. I hope that makes sense. Thanks in advance for your help!
https://imgur.com/a/oB1acY0
