Contour Cut
Discussion in 'Flexi' started by captainron19, Jul 12, 2005.
  1. captainron19
    captainron19 Member
    316
    1
    18
    May 11, 2005
    captainron19
    OK Using Flexi Pro 7.0 I wanted to have a contour cut of some text.
    I created the text - selected "effects" then "Contour Cut" I set my offset at .125 to have a 1/8" shadow for text - I chose "Apply" - next I went to "Effects" and chose "Seperate Contour Cut" I seperated the two items and they looked fine.
    The problem I ran into was when I went to cut them. The original text would appear in production manager but the contour would not.
    I thought I might have to convert it to curves so I did that but then when I went to Cut - not all of the letters appeared in my preview box.
    For instance - the Contour Cut was for the word "BRODENTOWN" after I converted to curves and went to cut the production manager only showed the letters BORD and then the O (Properly spaced) missing the ENT in the middle and the WN at the end.
    Am I missing something?
  2. jayhawksigns
    jayhawksigns Very Active Member
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    Are you trying to print and cut something, or are you just trying to cut your letters out of reagular vinyl??
  3. Fred Weiss
    Fred Weiss Merchant Member
    20,917
    544
    113
    Sep 11, 2003
    Olympia, WA
    Contour cut is used with printed images. For vinyl cutting just send the text to Production Manager and then on to your plotter. If you want to outline or shadow the letters, then you use the Outline or Shadow modification tool and with whatever color of vinyl you want that to be.
  4. captainron19
    captainron19 Member
    316
    1
    18
    May 11, 2005
    captainron19
    just cut
  5. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    If you are just cutting then there is no need to worry about the contour cutting option, like Fred said, thats only for when you are trying to print and then cut afterwards.
    All you need to do is select you text, and the select the cut/plot option and your golden.
  6. Bobby H
    Bobby H Very Active Member
    2,249
    204
    63
    Feb 4, 2005
    Lawton, OK
    One more tip with Flexi when cutting vinyl.
    It doesn't happen everytime, but it does happen. Just to be safe, I usually make separate copies of the items I'm about to cut and give them a black fill. At times when you have imported artwork items with white fills (or no fills at all) Production Manager may not add them into the plotting window.
  7. Scott Reynolds
    Scott Reynolds Active Member
    828
    You want to use the "outline" tool...
  8. captainron19
    captainron19 Member
    316
    1
    18
    May 11, 2005
    captainron19
    Thanks - what I was really trying to get was red letters with a 1/8" inch even outline of black around each letter. For something like, this, am I better off with the inline choice rather than the outline?
  9. Scott Reynolds
    828
    NO, outline not inline.
  10. Color Dude
    Color Dude Member
    217
    You do realize in the cut/plot screen, you have the ability to change the colors your cutting, or you can send all colors.
    If your doing 2 colors, of course you need to make sure that you have the color your wanting to cut selected on the general tab of the cut/plot screen, with the appropriate color of vinyl in the plotter.
    If you do alot of this, it sure would save you a ton of time if you had a printer. Layering jobs is not so difficult but if alot of your work consist of more than one color of vinyl as most jobs do, having a printer would cut that time in half if not more, and it sure looks alot better.
    Also maybe you should consider upgrading your Flexi 7.0 to the most current version of 7.6 v2, Scanvec has a couple of bugs still in it but much better than 7.6v1.
    Just some food for thought
  11. Fred Weiss
    20,917
    544
    113
    Sep 11, 2003
    Olympia, WA
    Ron, did you know that upgrading to the current version 7.6v2 is free to all registered owners of version 7 or higher? All you hasve to do is pay for the shipping.
  12. whynow
    whynow Member
    118
    Or just download it from Flexi.
    [link]http://www.scanvecamiable.com/products/flexi.asp[/link]
  13. captainron19
    captainron19 Member
    316
    1
    18
    May 11, 2005
    captainron19
    No I didnt know that - thnaks Fred - Guess I never did the upgrade because I have been using for such a short time and never had a problem with it.
    Gonna go and check into it now.
  14. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    A note on upgrading I recommend NOT installing 7.6v1, v2 should be released shortly, still isn't on the download page yet, just call you dealer.
    7.6v1 had problems to put it lightly.
  15. SMSupply
    SMSupply New Member
    8
    FlexiSIGN 7.6v2 and PhotoPrint 4.6v2 are for ScanvecAmiable dealers ONLY at this time. It has been added more devices, fixed some bugs, but it also has some bugs inside and it is still being solved.:Oops:
  16. jayhawksigns
    1,209
    34
    48
    Jan 8, 2005
    Kansas
    v2 is buggy too. Sound like everyone in the programming field for computers can't do anything anymore.
    Just like EA's Battlefield 2, that piece of gaming is awesome when it works, but its buggy as hell.
