captainron19
OK Using Flexi Pro 7.0 I wanted to have a contour cut of some text.
I created the text - selected "effects" then "Contour Cut" I set my offset at .125 to have a 1/8" shadow for text - I chose "Apply" - next I went to "Effects" and chose "Seperate Contour Cut" I seperated the two items and they looked fine.
The problem I ran into was when I went to cut them. The original text would appear in production manager but the contour would not.
I thought I might have to convert it to curves so I did that but then when I went to Cut - not all of the letters appeared in my preview box.
For instance - the Contour Cut was for the word "BRODENTOWN" after I converted to curves and went to cut the production manager only showed the letters BORD and then the O (Properly spaced) missing the ENT in the middle and the WN at the end.
Am I missing something?
