Contour cutting from photoshop to flexi
Discussion in 'Flexi' started by brad daggy, May 15, 2009.
  1. brad daggy
    brad daggy Member
    56
    I designed a logo in photoshop. How do I create a contour, save, and import into flexi 8, and then create contour for rip?
  2. OADesign
    OADesign Active Member
    797
    54
    28
    Jan 27, 2006
    California
    I'm assuming you have a good handle on photoshop and
    I'm assuming your graphic is on a solid or transparent background.
    Take your magic wand tool and select the transparent area. Then select the inverse. Your logo should be selected. then go to your paths palette. from the option menu select "make work path". You will get a dialogue box that will ask for pixel tolerance. I usually stat out at .5 and play around till I get a good result. Then once you are satisfied with the result, choose file > export > paths to illustrator. Save the file. then you can import the AI file into flexi to use as the contour path. If the path is not spot on you can always edit it in flexi.
    Another way would be to just use the pen tool in Flexi to draw the path then use it as the contour shape.
    hope that helps.
  3. brad daggy
    brad daggy Member
    56
    thanks for your help. But when I create a work path, it only exports the outline, not the image I need to also print.
  4. bob
    bob Major Contributor
    5,302
    316
    83
    Nov 4, 2005
    earth
    Assuming the Photoshop work is a bitmap...
    Import the file into Flexi.
    If you want to contour around the image and not the image's bounding rectangle, do Bitmaps->Make Transparent and select the background.
    Select the image, transparent or not, and do Effects->Contour Cut.
    Send everything to the RIP and Print. It will sort out the contour from the image for you.
    And there you are...
  5. OADesign
    797
    54
    28
    Jan 27, 2006
    California
    I assumed you had the flexi part figured out. Once you save the graphic, you need to import it into flexi as well. Then place the outline over your graphic. Then as I mentioned before use the outline as you contour shape.
