Ok... So the below graphic is what was printed by someone else (not using flexi). I've added the registration marks via AI, my VE Q100 picks up the registration marks fine. I'd prefer to just do it direct from AI as it would be easier, but apparently the Q series is not compatible with cutting master.
My question is, how can I add contours to this graphic in flexi and get everything to cut properly.
My steps were this:
1. Import the AI file into flexi, make the dimensions in flexi exactly the same as the outside of the registration marks
2. Add the contours I want cut in flexi. (The graphic below does not show the contours)
3. Do the automatic ARMs on my cutter, let it recognize all 4 marks (which it does).
4. Send file to production manager and remove any kind of spacing or margins.
It 'kind of' works. It's off anywhere from 1/16" to 1/4" depending on the direction. On this particular graphic I have a lot of leeway and its no big deal... but on future ones it needs to be accurate. Am I just getting lucky and this process isn't going to work at all? If so how can I cut something that isn't printed in Flexi.
My steps were this:
