Corel document sees something that I do not
shuv76
YOU COULD HELP US...... by posting a pic of what it CUTS!!!!! ALSO.....what ROLAND CUTTER, what version of the driver, your OPERATING SYSTEM...mac, pc, win XP, 7, or 8. as for HPGL or GPGL... HPGL...is default on any roland....DO YOU HAVE THE ROLAND MANUAL for your model of ROLAND???
It is so small it will not even show on a pic. It cuts about 1/16 of inch high and 3/8 wide. Just garbage . I have looked at it under a magnifying glass and it is nothing recognizable.. It is a roland gx24 & operating system windows 8. I set the default settings last night. I have been cutting with this system for a while with no issues & now it has gone bezurk.
shuv76
so you just use the roland driver and 'print' directly to the plotter?
Yes ,,,that is all I do....I have an update,,,It is working correctly now! I have tried it a few times since setting the default & it seems to be working correctly now.
Thanks so much for the help all of you. It sure is nice to have a place you can go to where people help.
Thanks again,,,Paul
OldPaint
yes jhill.........you can cut direct from COREL........to a ROLAND.........nothing else needed.........I discovered this back in 1992......when i was able to cut directly from from my COREL V 3 to my PNC-1000........... and i sorta told everyone else......how its done. since 1992....i have cut every piece of vinyl..........this way)))))) iam now using COREL X3 and a ROLAND CX-300........works flawlessly............
i also have been able to cut to my roland from illy, ARTS & LETTERS..........without any thing between them.
MakeMyGraphic
if it ONLY goes to the top left and starts cutting garbage data, I'd say you have your plotter set up wrong (most likely GPGL vs HPGL)
I second and THIRD this... I had two different machines at two different times of their lives present me with this problem, just look up your manual and switch to the proper mode and you should be in the clear. Sorry if this was solved already, I had my Graphtec to this to me as well as my old Roland CX-24 it is a plotter setting and not a computer program issue there.
EDIT: I see the problem is resolved now, interesting haha :) still leaving my original post as is just because. Useful info on here.
