CorelDraw: Back of Layer Question
54warrior
Hey folks, I have a quick question about Corel Draw. Often, I have items in a Powerclip and I want to move one of them to the back of the Layer, so it's at the back of the Powerclip. When I right click and go to that function, it shows I can press Shift+PgDn and it should perform the same function. It doesn't. In fact, none of those shortcut things that are in a "second level" flyout window ever work for me.
What am I doing wrong here? (screen grab attached)
Jean Shimp
I have a similar issue when I try "page up" to move an image to the top of the layer. If you click "save" after doing the page up, it goes to the correct layer. It seems to be a bug in the program.
myront
Dammit, make it faster!!
Let's see if I understand you correctly. You want to move a shape that is in the powerclip behind other shapes within the same powerclip?
bob
Right click on the powerclip object. Select 'edit powerclip content' or something like that. Arrange the powerclip contents in whatever way that gets you off. When you have everything the way you want it then do 'finish editing this level' and all of the contents will neatly be tucked back into the frame.
myront
you can also hold the alt key and select shapes inside without going into the powerclip. USe tab key until you get the shape you're after then use the cntrl+ page up/down keys
houseofmayhem
In Arrange-->Order, you can move things in Power Clip. You need to be in the PC frame and have the item you want to move selected.
unclebun
I just tried doing what you are asking about. I can do the move up/down both by right clicking in Object Manager and using the mouse to click on the up/down or by selecting the object in Object Manager and just using the keyboard shortcut to do what I want.
decalman
I been using Corel 14 years. I use the layer thing all the time. Don't really know what your problem is. When I get stuck....I just, wing it. :donderwolk:
