Creating Vector from a jpeg
Ok, so trying to figure this out with flexi 22.1. I have a vector shape i want to cut out from a jpeg image.
Flexi says "
Converting Marquees to Objects​
You can convert marquees into vector objects.
  • Select the bitmap.
  • From the Bitmap menu, select Convert Marquee to Shape.
But all is get is my vector shape in a dotted line? How do I pull it from the jpeg??
Thanks You!!!
weyandsign
Hey there, make sure your shape is on top of the jpeg. Then select the jpeg, hold shift, and select your shape. Then go-to Arrange -> Mask -> Mask
