Need Help Curved Shelf Talkers
Bojoz
Hi everyone,
I usually do standard .030 Styrene shelf talkers with a small right angle "L" bend for supermarket shelves. Client wants some done (same stock) but slightly curved..since the shelves all have a slight curve to it..so the "L" bent part must also follow a slight curve. Shelf talker has to be approx 30"w x 2"h x 1" bend (heat bend)...any ideas?..apart from doing the multiple cut technique. Thanks!
petepaz
what if you made some sort of male/female mold put the shelf takers in that and then heat them. maybe use cardboard cores from roll material?
never did it before and no idea if it will work just throwing out ideas
oksigns
I fab custom shelf talkers using Sihl's Durasol line of products. It sounds like the perfect product for things like this. They wont mind the bend if you get the "tab" cut right.
I will tell you once a slight bend is introduced across the plane of the sign, that slight bend imparts rigidity that make the need for a thick material negligible for something like a hanging shelf talker.
