you can make it any color you want in illustrator also. another way to do it is to import the color swatches from versa works (if that's what you are running) you can import your color swatches from the versaworks color library and also the color swatches for versa works (CutContour, white, metallic,gloss)improt them into illustrator and then you can open them up from your color library window
