Cut Contour issue with PDF.
Hi All,
I'm having issues with the cut line not showing up in Versa Works coming out of Corel Draw as a PDF. It only happens occasionally & I'm not sure if has to do with the way I export the file or what. The file is a vector & the cut/contour line is in the PDF when I import it back into Corel, but it will not show up in Roland Versa Works.
The same file & cut line show up fine if I export as an EPS but the file has a gradient & PDF version prints much cleaner. PS - If I send the cut line alone without the graphic, (in PDF format) it shows up just fine. Any ideas?
  • WrightLight 3x3 final.pdf
cornholio
What Versaworks version are we talking?
If it's 5.51 or lower, it's a known issue and you have to live with it.
Jason Thomas
Try the attached. Long time VersaWorks user here. I actually have version 5.51. I think the inability to see the contour cut has to do with transparencies in the file. Try saving your pdfs as Acrobat 4 (PDF1.3) and set your Overprint/Transparency Flattener to High Resolution in Advanced settings.
  • WrightLight 3x3 final_CUT.pdf
Thank You. I will try it & will write down the hints for next time as well.
Got it to work by converting the original AI file to eps before importing to Corel Drive. It must be something to do with AI & Corel not playing well together at times. I will definitely remember the tips for next time though. Thanks all!
jornyfloy
Great. Thanks for sharing the solution. I'll give it a try too, as I have a similar issue.
Attila Nagy
You just need to Flatten Transparency before adding CutContour. Deselect CutContour and do not convert Stroke to outline if you do it after.
Kemik
I sell stickers and sticker accessories.
When all else fails, make 2 seperate PDFs with the same size Artboard.
1st file is print only, no die line.
Choose the Roll Back/Return to base point feature in VersaWorks.
Then run the 2nd PDF with die cut only.
jornyfloy
Hi All,
By the way, I was recently recommended the SVG to JPG Converter https://pdfguru.com/svg-to-jpg which works great with vector files and can also convert them to PDFs. I want to try it out myself to see how it works.
