Cut is our of registration???
Discussion in 'Roland' started by SCOTTD, Dec 4, 2008.
  1. SCOTTD
    SCOTTD Member
    114
    I am having an issue with a print cut file.
    I can print lam & cut cutter finds image and cuts correct.
    If I do just a print cut it cuts out of registartion .
    Anybody had this happen before?
    Roland tech says encoder strip has gone bad??
    Thanks Scott
  2. petepaz
    petepaz Major Contributor
    4,340
    82
    48
    Feb 14, 2007
    NJ/NY/PA
    new one for me
    good luck
  3. SCOTTD
    SCOTTD Member
    114
    Cutline Issue Fixed!!!
    The linear encoder strip had dust on it wiped it with a cotton glove and it works fine!!
    Just take your thumb and index finger and gently wipe down both sides from right to left and you will be supprirsed at the amount of dust in there!!
